Internet Randomly Dropping Out
Internet will be fine one minute, white light showing on router. Then randomly I will lose internet on all devices, router light is flashing orange. Sometimes it will be fine for half an hour, sometimes only 5 mins between each drop. Had the exact same issue a few weeks ago which went on for about 4 days until an engineer came out and sorted it. That time a fault was picked up on quickly when I reported it and engineer booked.
This time both talktalk phone support and live chat said they can't find any issue, are not sending an engineer and I should just check the software on my devices, which is 100% clearly not the issue!!
I work from home and trying to deal with this is already costing too much valuable time and I can't get any help from talktalk it seems.
Hi @rsmith888 ,
It would be worth going to the Service Centre to do a test on your phone line, this will indicate if there is currently a fault on your line. You can also access this from the ‘My Account’ site.
If your master phone socket has a test socket then you could also try the router in there, that would then eliminate any of the phone wiring in your home as being a possible cause of the problem.
For one of the TalkTalk staff on this forum to be able to look into this you will need to update your community profile to include your name, landline telephone number that your TalkTalk service is provided on & an alternative contact number. This will allow them to identify you, and they will then be able to help.
Hi rsmith888
  • Name
  • Telephone number
  • Alternative contact number
