Internet drop
9 REPLIES 9
Hi all, my internet goes around the same time every day between 15.30 and 16.00 not sure why, using hg635 router  can take a while to come back on
Hi @leecarey your post has been flagged for assistance and you should hear during tomorrow. Is this a continuation of your problem from last year?
Hi leecarey, I've run a couple of line tests and they're both clear and show your connection is good. Is your router connected to a power socket or a multi gang with other devices? Have you got another router you can test with?
Ady
Hi ady
I have got 2 other routers, but they were unreliable , so I went back to my old hg635, seems to be ok at the moment
Cheers lee
Hi Lee,
Is everything still ok ?
Hi all narrowed it down its its  the WiFi that drops out randomly done it loads today
Cheers
Different problem from last year
Cheers
Hi leecarey
Does WIFI drop on all devices?
Would you like to try a replacement router?
All devices drop,
Cheers lee
Hi Lee
Would you like me to send a replacement router for testing?
