Internet light red.
Jamesdoolin
Good evening all. I have a d link dsl 3782 talk talk router. I have been with talk talk for about 7 months with no problems.
This is last week or so the lights flash and the internet light goes off and then eventually comes back red. I am getting very frustrated with this as I’m having to use 4g on my phone to tether my laptop.
I have reset but and I have looked at the talk talk helpdeak which says everything is ok. It’s clearly not.
May at I ask for some advice as I have no faith in it working consistently.
Many thanks in advance
James
James Doolin
When the internet light is red on the router, (or the status light is amber on the new TalkTalk Wi-Fi hub) the connection to the exchange equipment (or fibre cabinet if fibre) is normally OK, but there is a virtual path that needs to exist from this equipment to the internet. It is this virtual path that is down. This can be caused generally by:-
  1. Authentication issues
  2. Network issues
  3. IP filter issues
  4. An unusual line fault that does not affect basic connection.
  5. Router configuration issue or faulty router
The best way to resolve this is for me to pass this to one of TalkTalk's OCEs to investigate the condition for you now.
The forum is not real time 24/7 support, so depending on how busy they are & how many are working at any one time, this can take 24 - 48 hrs (excluding weekends & limited cover on Bank Holidays). Alternatively, you can call the call centre or use on-line chat. The posts are responded to in time/date order, oldest first. So the fewer entries you make on your thread now, the sooner they will pick it up.
Please make sure that your community profile includes your first & last names, broadband phone number.
Jamesdoolin
Thank you Keith.
I will try and update my profile with my phone number.
Its so so frustrating as it was working perfectly til very recently.
Best wishes
James
James Doolin
Hi James,
I'm sorry to hear this and I'll take a look now. I've run a test on the line which has detected a potential fault.
Just to confirm, are you experiencing any issues with the voice service such as noise on the line or no dial tone? Does your master socket also have a test socket?
Jamesdoolin
Hi Michelle
i don’t use talk talk for phone. Just my mobile.
I am am not sure if I’m plugged into my master socket. I will check.
What sort of fault have have you discovered?
kind regards
James
James Doolin
Hi James,
Do you have a handset that you can test with to rule this out? A voice fault can affect the broadband connection and would need to be investigated first.
Jamesdoolin
Hi Michelle
i have a cordless phone that I have connected this morning.
The light on on the hub is still red.
Is is it an easy fault to fix.
Many thanks
James.
James Doolin
When connecting the phone, was there a dial tone with no noise or crackling on the line ?
Jamesdoolin
Hi Karl
thank you for the quick response.
I just tested it by phoning my mobile.
It it was so crackly. It had a dial tone and my mobile rang but the crackles were evident.
I hope this helps.
BW
James
James Doolin
The broadband and phone share part of the line so if there is a crackle on the line this will impact the broadband causing slow speeds and dropping connections.
This is not actually a broadband fault but a line fault so now that this has been identified we can progress for a line engineer.
BT Openreach will always issue blanket conditions for any fault we report.
I'll send you a pm with the info required to arrange an engineer.
Jamesdoolin
Hi Karl.
I have PMd you.
Also noted a very very drastic reduction in BB speed.
Related?
bw
James
James Doolin
I've logged this out for a Non Appointed engineer - Non appointed means the engineer will be dispatched to look at the line without requiring an appointment be made with you to visit your property.
If Openreach ask for an appointment I'll book this in and let you know.
Jamesdoolin
Thank you very much for your ongoing support
James Doolin
Hi Jamesdoolin
Please can you post back on this thread later today and we can check for further updates on this fault.
Jamesdoolin
Hi Debbie
your colleague has arranged for an engineer to check my line externally. I don’t know if I will know if that has happened?
however my BB is very slow at 4mbs. It should be way faster. I have used talk talk checker and it says all ok.
Is is it related to my line issue.
Many thanks
James
James Doolin
Hi James
I've requested an update on this fault from our Network Team and I will post back on this thread as soon as I receive further information.
Hi James
Our Network Team have advised that this fault is still under investigation with a BT Openreach line engineer. We should receive further updates within the next 24hrs.
Jamesdoolin
Many thanks
James
James Doolin
Hi James
Please can you post back on this thread tomorrow and I can chase for further updates.
