@OCE_Debbie the speed test I sent to the other day was a lot lower than what you have sent me it was a wired test but you guys have not mentioned anything about that speed test
Hi sharky110
Please can you run the speed test again, when connected wired and with only 1 device connected?
@OCE_Debbie speed test ping 20 download 31.8 upload 6.7 wired
Hi sharky110,
Thanks. This speed test result looks ok as the throughput speeds are usually around 80% of the sync speed. If possible please can you run a few more wired speed tests over the next few days so we can see if they remain consistent.
@OCE_Michelle I will do you need me to send the results to you on hear
Hi sharky110,
If you could run the speed tests using the TalkTalk Speed Tester and then post here to confirm once this is complete then we can check the results for you.
Thanks 🙂
@OCE_Michelle just done a speed test ping 18 download speed 24 upload 6.8
@OCE_Michelle just done another test ping 17 download 37.7 upload 7.0
@OCE_Michelle just done a test ping 19 download 18.5 upload 6.5
@OCE_Michelle just tried to do a speed test it said no internet connection managed to get a connection done speed test ping 15 download 35 upload 7.1
@OCE_Michelle just done another speed test ping 16 download 26 upload 6.7 also I am have problems with tv recordings they are not recording properly ie the recordings are stopping and not restarting so ie only 20 mins of one program second recording 30 mins program was an hour in length so that tells me my internet is losing connection these were internet programs
@OCE_Michelle just done another speed test ping 18 download 26.9 upload 6.8
@OCE_Michelle my tv has just gone of saying no internet connection did it register your end
@OCE_Michelle another speed test ping 20 download 35.7 upload 5.1
@OCE_Michelle just done another test ping 17 download 35.6 upload 7.0
@OCE_Michelle every time I am trying to get on a website it keeps saying no internet connection I am connected but it will not connect to website I'm getting fed up with this can you please reply and tell me what you are going to do
Hi sharky110,
Sorry for the delayed reply, we're doing our best in these unprecedented circumstances due to the Corona virus to answer everyone as quickly as possible.
I've re-run the line test which is still clear, the connection looks very stable and the sync speed looks consistent. As this appears to be related to the wireless connection and you've tested with a different router, then the next step would be to arrange a TalkTalk engineer to complete some testing at the property, however due to the Covid - 19 guidelines we can only arrange engineer visits for total loss of service faults at the moment.
Have you tested with a wifi hub?
