@OCE_Michelle I think I have got the wifi hub but I have not got another router to test it with so have only tested on this router
@OCE_Michelle I have not tested with another router I only have one I think I have the wifi hub so what can we do now
@OCE_Michelle I have not tested with another router but I have got the wifi hub I think
Hi sharky110,
I'm really sorry for the delay in getting back to you. Are you happy for us to send a replacement router for testing purposes to rule this out?
@OCE_Michelle my internet tv channels are breaking up and pixalating
Just looking through all this and noticed your picture of the plugs. Wifi extenders and powerline adaptors never work correctly if they are plugged into extension sockets and even worse if they are surge protection ones, as they pick up interference from the surge protector.
I had the same problem kept disconnecting and poor speeds, plugged both powerline adapters straight into the wall sockets and never had a problem since. I now have 4 powerline adapters plugged in now including a wireless one in the garage without any problems.
Hope this helps
Mark
@ifanyonecan thanks for your info my powerline adapters are all plugged into a wall socket now they have been like this since those pictures I did it straight away but I am still having problems with my connection it's always up and down never consistent
