Internet speed getting slower and slower
Whizz Kid
We had an engineer out,  Speeds went back up to what they were.
Now back down again.
Playing GT5 on the Nurburgring Nordschleife with my Chrome Enzo Ferrari 😉
Hi Gizmo1981,
Thanks for the PM, I've raised this to our network team, can you bump the thread tomorrow and we'll check for upates
Whizz Kid
Bumping as requested.
I've tried shutting off the router for an hour to force DLM resync and it's still slow.
I'll email our network teams and see if they have an update for you.
Hi @Gizmo1981
An engineer has been booked for Tomorrow 20th AM (8-1).
Whizz Kid
Thanks,  I hope this issue is finally resolved this time.
Having just a DLM reset every time an engineer comes out isn't really a long term solution and let's face it,  I've had this issue since May,  So a resolution time of 6 months isn't really acceptable really.
I'll see what he says and if there's anything he can do to make sure the issue doesn't rear it's ugly head again.
OK, we are seeing a copper joint issue from here.  You can always mention this and see if he has identified the same from your end.
Whizz Kid
He said I may have said something like that.
Hes connected us to a spare line at the pole and I guess we'll see how it goes from there.
Speeds show a stable 38mbps down and 10.2mbps up as of typing this, so all in all a good result.
Let's see how long this lasts.
Thanks folks, I'll post back if anything crops up.
Glad to hear things are looking up.  Monitor and let us know if anything changes.
Whizz Kid
short lived and the engineer didn't really do anything.
Speeds now well below what I've been having previously.
http://www.speedtest.net/result/7862604478
Can we PLEASE have something done so this is finally fixed.
Having this happening at all is bad enough,   Having it happen from May to December is abysmal!
:edit:
Just dropped again.
http://www.speedtest.net/result/7862607733
Whizz Kid
Another speed drop.
Line Quality
Upstream line rate (kbit/s):9998
Downstream line rate (kbit/s):19920
Upstream noise safety coefficient (dB):6.3
Downstream noise safety coefficient (dB):5.1
Upstream interleave depth:0
Downstream interleave depth:0
Line standard:VDSL
Upstream line attenuation (dB):0
Downstream line attenuation (dB):0
Upstream output power (dBm):7.6
Downstream output power (dBm):11.9
Downstream interleave depth:None
DSL up-time:
0 days 0 hours 2 minutes 35 seconds
Update : new drop
Line Quality
Downstream line rate (kbit/s):15938
Upstream noise safety coefficient (dB):5.5
Downstream noise safety coefficient (dB):2.6
Line standard:VDSL
Upstream output power (dBm):7.5
Downstream output power (dBm):11.5
DSL up-time:0 days 0 hours 8 minutes 27 seconds
Hi Gizmo1981
I've completed a line test which has detected a possible fault. Can I just check if your landline service is working ok before I pass this back to our Network Team.
Whizz Kid
Please do.
Currently router stats are showing :
Line Quality
Upstream line rate (kbit/s):8496
Downstream line rate (kbit/s):16494
Upstream noise safety coefficient (dB):8.9
Downstream noise safety coefficient (dB):16.9
Line standard:VDSL
DSL up-time:0 days 0 hours 3 minutes 3 seconds
I should mention that the majority of speed drops are when it is windy or when a gust of wind comes.
Hi Gizmo1981
Whizz Kid
Line is pretty crackly when I pick the handset up.
Hi Gizmo1981
Noise on the line can affect the broadband connection so we have to investigate this first.
Is the noise still present if you test with a corded handset at the test socket, with the router removed from the line?
Whizz Kid
There's only noise on the line when the weather is bad ( rain / wind )
Hi Gizmo1981,
I'm sorry for the delay. One line test is clear and the other line test is detecting a potential issue towards the property. Is the crackle still present at the test socket with all other equipment removed? As soon as we've confirmed this then we'll pass this straight over.
Whizz Kid
phone is connected to the test socket and there is a little bit of crackling on the line.
Until we get bad weather again I can't say how bad the crackling will be.
Whizz Kid
Router stats are as follows as of now
Line Quality
Upstream line rate (kbit/s):4295
Downstream line rate (kbit/s):9999
Upstream noise safety coefficient (dB):15
Downstream noise safety coefficient (dB):21.6
Line standard:VDSL
Upstream output power (dBm):4.9
Downstream output power (dBm):10.6
