for the past couple of weeks I have woken up to very slow internet, which has required a reboot of the router to fix. I did tests this morning and yesterday on www.supportal-test.co.uk and put in my phone number at the end so you should have the results. I've attached a screenshot as well.
Tests done over Ethernet, not wifi. Reboot gets the speed back up to over 20megs.
Internal network, both wifi and ethernet, work fine when this occurs, I can still steam videos across the network and copy files with no slow down.
If you check this account you will see fibre slowing down has been a constant problem since it was installed
Hi JohnFielder1
Does the reboot of the router increase the speed straight away?
Which router are you using? (make and model)
The speed increases straight away
The router is an HG633
Same again this morning. Did a supportal-test.co.uk speedtest before rebooting
Hi JohnFielder1
I can send a DSL3782 router for testing, have you previously tested with this router?
I am on my 7th or 8th router. I have had HG633s and DSL3782 (I think) Do you not have records?
Different routers made little difference. The DSL was a slower connection
The speed has been very reliable, with the router being stable for over a month at a time. Then, what I presume was DLM change restarted it with a higher sync speed. This has been going on ever since. Can you set the sync speed back to its earlier level?
Hi John,
Unfortunately we are unable to manually change line profiles, DLM does this automatically and we have no manual override
Just to confirm, have you tested with a second router since you started experiencing this issue a couple of weeks ago?
OK thanks, I think we should test with a second router, what was the problem with the 3782?
OK thanks, I think we should try a different make and model of router before logging over to our network team so are you OK for me to send another 3782 to test with?
Yes we can only send the 633 or 3782. I've ordered a 3782, it should be with you within a couple of days but please allow up to 5 working days for delivery
Hi John,
I'm sorry to hear this and I'll take a look now. The line test is clear. Just to confirm, are you using all the new cables and microfilter that came with the replacement router?
Does your master socket also have a test socket? As soon as we've confirmed this then we can pass this over to our Network Team and ask them to take a look.
Hi JohnFielder1,
Is your router currently connected to your test socket?
No, it's not connected to the test socket. No one has asked me to do that
Reconnected last night, presumably DLM again. Now syncing at 19,400
Is this DLM or is this router disconnecting whereas the other one just went slow?
Hi John,
Thanks for confirming this. Would it be possible to connect the router at the test socket for 48hrs to see how the stability compares and also to see if the speed remains consistent?
