Line Speed
3 REPLIES 3
Hi, when I first took out faster fibre, I was told my max line speed was 39 which it pretty much is wired. I'm just curious if that's still my limit or is an upgrade available? Thanks. Leighton
Hi systemlord2000,
If you check your My Account it should tell if you can add the faster fibre speed boost
Thanks for the reply. I checked and it said I can boost for £3 extra a month. But my point is, if my line is still limited to 39 what's the point? Can anyone here DM me and check my line's capabilty please? Thank you.
Your line is limited to 39 meg artificially because of the package you are on. Nobody can do more than estimate what would happen if the limit was removed, but TalkTalk no longer offer the faster speeds to those with lines which would not see a significant improvement.
Your router stats may give you a rough idea, or use the BT Checker option here, ignore the Phone Number and other fields and use the link for Address Checker.
