I have fibre broadband and for a long time I have had constant buffering every couple of minutes and I am now fed up with it. I’m looking for any help to rectify this please....
Hi Heidi3,
We'll then look into this further. Please do not post this information on this thread Once you've updated your profile please post in your topic to confirm it's updated.
Hi Heidi3,
Thank you. I've run a test on the line which hasn't detected a fault and the connection stats also look ok. Could I just confirm, are you connected wired or wireless when you experience the buffering?
The buffering happens with both wired and wireless connection
Thank you
Hi Heidi3,
Ok thanks for confirming this. Does the buffering occur on different devices? What speeds do you receive if you run a speed test when this happens? Is this permanent or intermittent?
Sorry for delay in getting back to you.
This is a permanent fault which happens on all devices. Whilst buffering the speeds drop down to around 7mb this lasts for a couple minutes and this may happen every 10 minutes or so. Hope this helps.
Hi Heidi3
Are any of your devices connected wired? Are these also affected?
Devices connected to internet are also buffering and situation not improved.
Hi Heidi3,
Could I just confirm, do you mean connected wired? (via ethernet)
Hi Heidi3,
Thanks for confirming this. The line test is still clear and the connection stats also still look ok. Which router are you using? (make and model) Do you have an alternative router that you could test with to rule this out?
Hi Heidi3
I can send a replacement HG633 router for testing, would you like me to arrange this?
Hi Heidi3
Hi, I have received the new router and the buffering has not really improved very much. I was thinking maybe I should upgrade my internet speed to see if this makes any difference, do you think this may solve the buffering? I can see that you charge an admin fee to upgrade though and I don’t want that extra fee to pay if it does not improve the situation. Is it possible to upgrade the speed for a day and see if it makes a difference to the buffering every 10 mins?
Hi Heidi3,
Thanks for trying this. I've re-run the line test which is still clear and the current sync speed does look ok. Are you using all the new cables and microfilter that came with the new router? Is the buffering still happening with just the one device connected to the line?
Yes I have changed all wires to the new ones with the router.
The connection is still buffering with the devices that are wireless and with the one that is wired. There is intermittent connection loss.
Hi Heidi3
Apologies for this.
The sync speed looks good - 39.2mb.
Are any other devices in use and connected at the time when the buffering occurs? What device are you using when this fault occurs?
