Line check says slow/ Talk to talktalk
37 REPLIES 37
Device Info Serial Number	N7190194N012893 Hardware Version	FAST5364 3.00 Software Version	SG4K10002600t GUI Version	3.7.5 System Up Time	1d 01h57m45s MAC Address	34:DB:9C:CE:C6:20 Network Local IPv4 Address	192.168.1.1 Local Subnet Mask	255.255.255.0 Local Ethernet Mac address	34:DB:9C:CE:C6:26 Public IPv4 Address	79.67.222.80 Public Subnet Mask	255.255.224.0 ipv4Duration	00h01m01s Default Gateway	79.67.192.1 Primary DNS Server	79.79.79.79 SecondaryDNSServer	79.79.79.80 ipVersion	IPv4/IPv6 NAT	DISABLED Wi-Fi 2.4 GHz Wi-Fi SSId	TALKTALKCEC626 Status	Enabled Uptime	1d 01h57m18s MAC address	34:DB:9C:CE:C6:23 Mode	802.11 b,g,n Security	WPA2 Personal 5.0 GHz Wi-Fi SSId	TALKTALKCEC626 Status	Enabled Uptime	1d 01h57m18s MAC address	34:DB:9C:CE:C6:24 Mode	802.11 a,n,ac Security	WPA2 Personal xDSl Line 1 Status	UP Connection Time	1d 01h57m50s Link Status	UP Standard	VDSL2 (G_993_2_ANNEX_ B) Line Encoding	DMT Link Encapsulation	ATM (G_992_3_ANNEX_ K_ATM) Line 1 Downstream	Upstream Actual Rate [KDevice Info Serial Number N7190194N012893 Hardware Version FAST5364 3.00 Software Version SG4K10002600t GUI Version 3.7.5 System Up Time 1d 01h57m45s MAC Address 34:DB:9C:CE:C6:20 Network Local IPv4 Address 192.168.1.1 Local Subnet Mask 255.255.255.0 Local Ethernet Mac address 34:DB:9C:CE:C6:26 Public IPv4 Address 79.67.222.80 Public Subnet Mask 255.255.224.0 ipv4Duration 00h01m01s Default Gateway 79.67.192.1 Primary DNS Server 79.79.79.79 SecondaryDNSServer 79.79.79.80 ipVersion IPv4/IPv6 NAT DISABLED Wi-Fi 2.4 GHz Wi-Fi SSId TALKTALKCEC626 Status Enabled Uptime 1d 01h57m18s MAC address 34:DB:9C:CE:C6:23 Mode 802.11 b,g,n Security WPA2 Personal 5.0 GHz Wi-Fi SSId TALKTALKCEC626 Status Enabled Uptime 1d 01h57m18s MAC address 34:DB:9C:CE:C6:24 Mode 802.11 a,n,ac Security WPA2 Personal xDSl Line 1 Status UP Connection Time 1d 01h57m50s Link Status UP Standard VDSL2 (G_993_2_ANNEX_ B) Line Encoding DMT Link Encapsulation ATM (G_992_3_ANNEX_ K_ATM) Line 1 Downstream Upstream Actual Rate [K
Gareth wigglesworth
Hi Gareth1986,
  • Name
  • Telephone number
  • Alternative contact number
Ok I completed it 100%. Here's th3 message I get...Screenshot_20190528-113112.png
Gareth wigglesworth
 Attenuation and power levels seem way out? Anybody confirm, thank you.attenuatiom
Gareth wigglesworth
Hi Gareth1986,
I've run a test on the line which hasn't detected a fault and the sync speed looks good. Just to confirm, are you running the speed tests wired or wireless? Could you try switching the router off for a full 30 minutes and then run another speed test to see if their is any improvement in throughput speed.
Gareth wigglesworth
7in the
Gareth wigglesworth
in the router it ssys im getting 80/20. Is this what i should be getting or what i am getting? Are my upload attenuation and power levels ok? They look out of whack. Why would it be negative 10?
Gareth wigglesworth
Hi Gareth1986,
This is the sync speed, the throughput speeds are usually around 80% of the sync speed. Could you run a speed test using the TalkTalk Speed Tester so we can see how the speeds compare in relation to the sync speed?
Thank you, I get that. But are they within range? On the upload?Screenshot_20190528-130049.png
Gareth wigglesworth
Do I ignore the message (your connection could be improved)?
Gareth wigglesworth
The power level on the upstream is all I'm concerned about. Thank you.
Gareth wigglesworth
Gareth wigglesworth
I'm not sure if this is a foreign help place but I seem to be getting nowhere. The power level on the up stream is minus 10, negative 10. Less than zero. -10. This suggests my upstream power level is well below what it should be ?
Gareth wigglesworth
Hi Gareth,
I'm sorry for the delay. The speed test results look good based upon the sync speed. Is everything ok with the overall performance of the connection? I wouldn't worry too much about the router stats if your connection is working fine.
The upload stats are way off. You know they are. Why are you doing nothing to resolve it? When I shoot people in online games nothing happens. They don't die, I know it's TALKTALK because I never had this happen on virgin. I check my line stats and the upload stats stuck out Like a sore thumb. But you say if your getting your speed don't wort about it. Well I am concerned, my car will do the 150mph on the clock but if any other thing is wrong with my car...dont worry about it? I'm still in the 30day cooling off period and are dissatisfied already. Gaming is not possible because nothing registers. Gaming is about upload and ping times. I cannot play on this. Please resolve or I will simply leave and go with BT. Gareth
Gareth wigglesworth
Hi Gareth,
If the performance is affected then we can look into this further. Is it only gaming which is affected? Does it affect wired and wireless?
Could you run a wired ping and trace route when you next experience this issue and post the results into the thread.
Run a Ping or Traceroute
I'm doing the tracert wired so I'll take a picture with my phone of the results on my laptop. Thank you for the help
Gareth wigglesworth
Gareth wigglesworth
It times out on the second hop everytime. This is resulting in games being slow/sluggish and when I shoot people nothing happening. I still have time to leave without paying anything. If it's not resolved by my cooling off period I'll have to leave. I can't be tied into this for 18 months
Gareth wigglesworth
This widget could not be displayed.
