Losing connection and slow speeds on HG633
76 REPLIES 76
Hi, I've been on fibre for about 5 months and it was fine to begin with, I was getting around 38-39 Mbps down and 10Mbps up. For the last 2-3 months it has often been losing connection and slowing down. I can see from the router stats page that both connection rates are low.
Prior to fibre, I rarely had any problems and always had maximum connection rates.
I have had the router connected to the master socket since 3pm on Friday 9th November and it has been constantly switched on since then. I have also tried it with a different filter previous to that.
Here is a copy of my router stats page at the time of posting:
Internet Connection
DSL synchronization status:
Up
Connection status:
Showtime
WAN IP Address:
92.12.126.171
Primary DNS Server:
79.79.79.79
Secondary DNS Server:
79.79.79.80
Line Quality
Upstream line rate (kbit/s):
5267
Downstream line rate (kbit/s):
7415
Upstream noise safety coefficient (dB):
11.5
Downstream noise safety coefficient (dB):
27.6
Upstream interleave depth:
67
Downstream interleave depth:
1269
Line standard:
VDSL2
Upstream line attenuation (dB):
0.1
Downstream line attenuation (dB):
7.8
Upstream output power (dBm):
4.6
Downstream output power (dBm):
12.2
Channel type:
Interleaved
DSL up-time:
0 days 15 hours 48 minutes 17 seconds
The broadband speed has dropped.
I am picking up a high resistance on the line.
Can you check the home phone for any noise on the line ?
Also, do you have a Test Socket and if so, connect the router direct to this so I can retest.
Hi, as I said, it's been connected to the master socket since Friday. The faceplate has been removed and it's in the test socket. That's the only socket in the house.
What do you mean by noise on the line? I rarely have a phone plugged into the socket but I have just connected one. The line sounds ok with maybe the odd crackle but nothing I would consider too abnormal.
The broadband shares part of the line with the phone. Any noise on the line can impact the broadband service.
When you say the odd crackle, is this more of a permanent crackle that you can hear every time you listen to the handset ?
Yeah, I've just had another listen to it and I would say it's permanent. Is that the sort of thing that would affect fibre more than normal dsl?
Even with fibre, the line from the cabinet to the house is copper, and this is the section that is shared between the 2 services, so any line noise will cause the broadband to drop.
I'll need to raise this to BT Openreach as a line issue rather than a broadband issue so this can be fixed and the line cleared.
With any engineer request, no matter what the fault, they always make a blanket set of T&C's.  I'll drop you a PM with the info required for the booking.
The next step will be to arrange an engineer visit to investigate further, to do this can you confirm:
To confirm you're the account holder can you PM (Personal Message) me with the following information:
  • Full Name
  • Home telephone number
  • Are you the account holder
  • 1st and 3rd characters of your password
  • If password is unknown, confirm the below:
  • How do we send the bills to you each month
  • email address
    Note: Please do not post personal information directly in the Forums.
So reading that, it says I could be charged if no fault is found. Given that I didn't have any line problems in the past 11 years before I switched to fibre, I'm not too sure about being potentially charged for not finding a fault. I'm not keen on paying for something that wasn't there or nothing to do with me.
The conditions are made by openreach for all faults, as they have never been involved in any diagnostics or spoken to you, so when a fault is reported they will always make this condition to make sure they are being sent out for a fault.
If you can here a crackle on the line then a fault exists and the only way to have this rectified is to progress to Openreach.
They will make these conditions to all suppliers and customers.
It is crackling although it's not permanent.
Ok then if you can drop me a PM I'll send you the necessary details and go ahead with that. I want to make it clear though that I'm not going to pay any charges that arise from this if they don't find a fault on the line. Thanks.
Our line tests are picking up a fault, that combined with the crackling you can hear on the line is evident enough that a fault exists.
I'll re-send the PM now.
  • Full Name
  • email address
Ok thanks. It looks like I'm not receiving any PMs as I can't see any of yours for some reason?
Might be an issue with our workflow tool.
I've sent this directly from my profile instead, check now.
Booking request placed.  I'll reply here as soon as this is confirmed.
Ok, thanks.
Appointment has been arranged for Thursday 15th PM (1-6).
That's fine, thanks.
Please let me know how things are following the engineer visit.
Yeah will do, thanks.
