Losing connection and slow speeds on HG633
Hi M Lynn,
We can send a different make and model of router to test with. would you like us to arrange this?
M Lynn
Yes please, I can't think of anything else to test and I don't have another fibre router to try. Thanks.
I've ordered a router, should be with you within a couple of days but please allow up to 5 working days for delivery
M Lynn
Thank you Thumbs_up
No Problem, please let us know how you get on with the new router 🙂
M Lynn
Will do, thanks.
M Lynn
Well, I'm still having frequent disconnections, even with a new router, and my download is now down to 25Mbps. At times it's totally unusable as the disconnections are just so constant. So it's not the router, it's not the cables or filter, I've double checked those, and according to the engineer the line is good. What does that leave? Is it possible the line has an intermittent fault on it that the engineer couldn't find? I'm at a loss now.
Hi M Lynn,
Thanks for trying this and I'm sorry to hear this. I've re-run the line test which has now detected a potential fault. Just to confirm, is the voice service still ok with no noise on the line?
Once we've confirmed this then we can pass the intermittent connection straight over to our Network Team for further investigation.
M Lynn
Hi, I don't use the voice service at all and I don't have a phone connected, but earlier in the thread I was asked to check for crackling on the line. There was a little bit but it wasn't constant. An engineer visit was booked, he checked the line and said it was fine. Thanks.
Hi M Lynn,
Ok, I've passed the intermittent connection over to our Network Team now. If you don't hear back by the end of today then please can you bump your thread and we can re-check this for an update for you.
Hi M Lynn,
I've now received an update to advise that the fault has been passed to BTOR for further investigation and we should receive an update back within the next 72hrs.
M Lynn
Ok, thanks for the update.
M Lynn
It appears this is still not resolved.
To summarise what has happened so far. There were no problems with my standard broadband until I moved onto fibre last year. Then I started getting constant disconnections and the line speed was constantly changing. An engineer has now been twice, replaced the master socket, and on both occasions said the line was ok and the problem must be with TalkTalk. A new router has also not solved the problem.
After the last update in December, the engineer arrived, and said there were no problems with the line. Since then, the router has been left switched on the whole time and everything has been fine for 3 months until last week when it started disconnecting again. It's getting more and more frequent by the day to the point it's now almost unusable and very annoying. I'm really not happy with this at all now.
Hi M Lynn,
I'm really sorry to hear this and I'll take a look now. I've run a test on the line which hasn't detected a fault, however the connection does look very unstable. Just to confirm, are you experiencing any issues with the voice service such as noise on the line or no dial tone? Have you recently added any new equipment to the line?
M Lynn
Thanks, I agree it's very unstable to say the least. No, nothing has changed at all, and nothing has been moved. I don't use the phone line and I haven't even got a phone plugged into it. I haven't done so for years. We have gone over all this, yes there was a slight crackle on it when tested but the engineer says there is nothing wrong with the line at all.
Hi M Lynn,
Ok thanks for letting me know. As the line test hasn't detected a fault would you like us to send another router for testing purposes or would you prefer us to pass this straight over to our Network Team for further investigation?
M Lynn
I'll try another router to test again first.
Hi M Lynn
