Loss of broadband speed (around 10Mbps)
30 REPLIES 30
I had an issue on 1st Feb 2020 where I had no broadband and I contacted TT via telephone and found it was an external fault and a OR engineer would need to visit the exchange.
Around 2/3 days later I had a txt message to confirm the fault had been fixed and I now have working broadband and telephone.
Since then my connection has dropped from around 26/7 Mbps and getting between 9/15 Mbps.
I have tried my test socket, I have a BT NTE5C Mk4 socket and using an uprated router Asus DSL-AC68U.
Is possible I can have my profile reset via TT or raised with OR / BT please.
Hi Liquid_NeoTheOne
I've completed a line test which hasn't detected any faults but I can see re connections on the line and this can affect the sync speed.
Is the connection dropping or has the router been rebooted?
Please can you leave the router connected at the test socket for 48hrs, without rebooting so we can see if DLM starts to increase the speed again (if the connection remains stable)
Hi Debbie,
Yes I have been having the connection drop, I did report this via txt message maybe a 2 weeks ago.
I have moved the router to the test socket again and will monitor it for 48 hours.
FYI - Connection normally is very stable but since the 1st feb these issues have happend.
Not to worry if the DLM can self rest and increase itself then fingers crossed.
Hi Liquid_NeoTheOne
Please can you post back on this thread on Thursday, we can then check the connection stats/speed again.
Hi Debbie,
Still no changes to the speed from what I can see,
I have checked my router as It live updates without breaking the connection
So
Max Rate -
Downstream
30584 kbps (This has increased)
Upstream
1063 kbps (This has dropped)
Yet my data rate is
Data Rate
Downstream
19999 kbps
Upstream
1063 kbps
Yet I am still getting poor speeds, The connection is solid no dropouts (We did have a powercut wednesday morning).
Any chance you can you can increase the data rate to match the max rate for the downstream?
Hi Liquid_NeoTheOne,
Thanks for bumping your thread. I can't currently see your connection stats. Just to confirm, are you using the TalkTalk router?
Hi Michelle, I am not i'm afraid using my own uprated rouer - Asus DSL-AC68U.
Ok thanks for confirming. Do you still have the TalkTalk router?
Hi Michelle,
I don't sorry.
Ok, would you like us to send a replacement router for testing to rule this out?
Hi Michelle,
I have test another router which I had spare and the speed loss is still there.
Sorry for the delay. Can I just confirm, is this alternative router still connected at the moment?
Hi Michelle,
Yes the router has been connected since Sunday.
Your sync speed looks really low at the moment, are you currently experiencing any problems with your telephone service, any noise on the line?
Hi Chris,
No noise on the line, telephone service seems to be working fine.
Adam.
OK thanks Adam, the next step will be to arrange an engineer visit. If you'd like us to go ahead with the engineer visit can you confirm:
Thanks Chris,
I have sent you details.
Is it possible I can have the test router just to ensure that the two third party routers are not at fault before I book the engineers?.
What is my line syncing at the moment?
Thanks for the PM
I've ordered a router to test with, it should be with you within a couple of days but please allow up to 5 working days for delivery
Hi Chris,
I managed to find my old talktalk router the HG633.
I have connected this, still no speed improvement. I will leave it connected to see if you can login and check.
I have turned off all WIFI and just have a wired connection to the laptop.
Thanks for trying the other router. Your current sync speed is 18.7Mbps. Could you leave the router connected to you test socket for 48 hours and we'll see if DLM moves you to a faster profile
