Low speeds or no connection
3 REPLIES 3
Wizz Kid
Some of the time the speed is very low (1mb to 2mb). Some time unable to connect.
Internet Connection
DSL synchronization status:
Up
Connection status:
Showtime
WAN IP Address:
Primary DNS Server:
Secondary DNS Server:
Line Quality
Upstream line rate (kbit/s):
9997
Downstream line rate (kbit/s):
39806
Upstream noise safety coefficient (dB):
9.2
Downstream noise safety coefficient (dB):
11.4
Upstream interleave depth:
1
Downstream interleave depth:
5
Line standard:
VDSL2
Upstream line attenuation (dB):
4
Downstream line attenuation (dB):
14.6
Upstream output power (dBm):
7.6
Downstream output power (dBm):
12.6
Channel type:
Interleaved
DSL up-time:
6 days 21 hours 45 minutes 25 seconds
Hi Shomel122,
I'm sorry to hear you're experiencing problems with your service. Your sync speed seems to be consistent at around 40Mbps. Do you experience the slow speeds on devices connected to your router by Ethernet cable or wifi?
Wizz Kid
Its both. Wired smart tv and mobile on wifi
OK thanks. Are you experiencing any problems with your telephone service? Any noise on the line?
