Lower sync speed than normal
11 REPLIES 11
mykobrien
Recently, my broadband sync speed has been pretty good (>8Mbps), but just this evening it has dropped to less than 5Mbps.
Please could my sync speed be reinstated to as high as possible once again? I have requested this in the past and it has been very successful.
Many thanks in advance
Hi mykobrien,
I'm sorry to hear this and I'll take a look now. I've run a test on the line which hasn't detected a fault so I've optimised the connection now. Please let us know how the speed compares over the next 24hrs.
mykobrien
Many thanks for this. I've arrived back today and it has not shown any difference so far. Do I need to reset my router?
Thanks for the help so far.
Hi mykobrien,
Just to confirm, does your master socket have a test socket?
mykobrien
Yes, it does
Hi mykobrien,
Thanks for confirming. Is the router connected to the test socket at the moment?
mykobrien
yes, it is now. I took the opportunity to plug in my hg533 router and it jumped to 7Mbps.
There doesnot not appear to be any line faults in the telephone side.
Thanks .
Hi mykobrien,
Thanks for the update. Is the alternative router still connected at the moment? Has the speed remained consistent since your last post? What's the make and model of the first router you tried?
mykobrien
Yes, for the past few days it has stayed at around 7Mbps. This is with the hg533 router. The other slower one is an hg633.
thanks
Hi mykobrien,
Ok, would you like us to send a replacement router?
mykobrien
Hi there,
Only if there is no cost incurred!!
Many thanks
Hi mykobrien,
