MS Direct Access doesn't work on new home hub
4 REPLIES 4
topcat1608
I see post relating to the Home Hub, but no easy solutions.
am also having this problem. My internet kept dropping so i was sent the new HomeHub, now I can't work from home remotely and access MS Direct Access which is part of my job! Please help asap.
TopCat
TopCat
Divsec
Hi Topcoat, welcome to the community your post has been flagged for assistance and you should hear during Monday. I suggest you check the Homesafe settings TalkTalk HomeSafe - An Overview
aswiseman
If it helps, I have the new Sagem hub and I also use MS Direct Access to work from home. It works OK for me. Although it can often drop out.
topcat1608
Thank you. I have the kidsafe prorgramme on, and have unticked this to see if it made a difference and it didn't. I look forward to hearing from you guys.
TopCat
Hi topcat1608
Please can you try factory resetting the router using the pin hole reset for ten seconds and testing this again?
