Manual IP configuration (WiFi hub)
1 REPLY 1
MR-HIPPO
Hi.
WiFi hub arrived today, and I am trying to manually assign static IP address to some of the devices on my network.
I have been on the phone to customer services, and they have updated my firmware to version version SG4K10002600t, and now have a  RESERVE IP button when managing devices in advanced settings.
My question is, how do I actually change the ip address value?
Although there is a button to "reserve IP" there is no input field to input the desired value.
Any help with this would be greatly appreciated, Hippo.
FritzCT
Wise Owl
I don't use the wi-fi hub so I'm not sure if you can choose the IP address or not but you can if you set the static IP address on the device rather than the router.
Fritz
