Minecraft portforwarding
4 REPLIES 4
How do i port forward a minecraft server? what do i need to put into the service/protocol.exteral host/external port/internal host/external port boxes?
Insightful One
Some of the talktalk routers have preconfigured rules for popular games etc, if that is the case then you just select Minecraft from the list and specify the IP address of the machine hosting the server. If not then you leave the external host blank and set the internal host to the IP address of the machine hosting the server. As for the ports and protocols they will be defined/specified by Minecraft.
You also need to make the IP address of the server static.
I have done all the steps that you have mentioned, but how do I make my IP address static?
Insightful One
It will depend on which router you have. The Talktalk port forwarding guide:
https://community.talktalk.co.uk/t5/Articles/Set-up-port-forwarding/ta-p/2205382
Gives details how to reserve an IP address on the various dlink routers.
Hi bruhmomentum
Another customer had an issue with Minecraft / port forwarding and resolved an issue, have a look at the read below to see if it helps.
https://community.talktalk.co.uk/t5/Broadband/Port-Forwarding-on-the-Sagemcom-Fast-5364-3/m-p/258067...
This widget could not be displayed.
