Moved house across the road and speeds are WAY down
I've now plugged my phone and router into the test socket with a microfilter.
Since plugging into the test socket my router is now showing these stats...
Upstream Downstream
Current Rate (kbps)706132139
Max Rate (kbps)713742172
SNR Margin (dB)6.16.2
Line Attenuation (dB)38.817
Errors (pkts)462979
I'm still getting max 20mb download but hopefully that should increase soon?
F
Hi Jacksonuk88,
Thanks for the update. If the sync speed increases, however their is no increase in throughput speed then we usually advise switching the router off for a full 30 minutes and then retesting the speed again as this will reset the current session.
Thanks for the info.
I'll try turning it off for a half hour tonight and post my results.
Fingers crossed!
Followed the instructions and I'm now getting 31mb on WiFi.
Hope it holds. I'll give the internet a good thrashing and respond over the next couple of days.
Thank you!! 😊
Hi Jacksonuk88
Thanks for your reply 🙂
How has the connection been over the weekend?
