Netflix freezing
3 REPLIES 3
Visitor
Hi all
Recently got a new smart TV,problem is when I use Netflix the picture breaks up and freezes and the tv tells me there is a internet problem,do I need a new router with a stronger signal ?
Any ideas would be very much appreciated
Hi @Roni737 ,
I'm assuming the TV is connected wirelessly ?, is it a significant distance from the router ?
There are a few things you could try to see if it is Wi-Fi interference causing the problems.
Split the SSID's on the router, this will allow you to give the 2.4GHz and 5GHz networks different names, so your Wi-Fi devices will then see those two networks separately, you can then try connecting to one or the other to see if one gives a more reliable connection than the other.
Change the channels that your router broadcasts the Wi-Fi signal on, you can use free smartphone Apps like this to see what channels are being used within range of your smartphone, you can then change your router to use channels that are less congested.
Visitor
Many thanks for your info,will give it a try and see if it solves the problem.
regards
Roni737
Hi Roni737
Apologies for the delay.
How has the connection been since your last post?
