I have just been sent new Huawei router but after installation when everything else seems to work, I cannot make a Remote Desktop connection across its internal LAN ports (or WiFi). The same connection works with the previous router so it appears to be something to do with the way the new router is handling tcp traffic across its LAN. Netbios connections like connections to file server appear to work across it. If anyone has any idea why this is happening I would love to hear.
Hi pirajeou,
I've replied on your other thread.
