New Line HG612+Asus
6 REPLIES 6
ignade
I received my Sagemcom WiFi Hub o last Friday and after some test I put back in its box because it cannot work as a modem. I own an Asus RT-3100  that is definitely better than talktalk version.
I bought a hg612 and I unlocked .
The modem is working in connection with Asus as router wifi.
Just I don't know which are the best settings.
For instance "DHCP transparent transmission" is enabled in my modem but I have found some pictures where is disabled.
Can someone advice?
Hi ignade,
@KeithFrench - Would you be able to provide any advice?
I cannot currently offer any advice on this, as I do not have the time currently to research products that I have no knowledge of.
Some of our other Community Members might be able to offer some advice on this.
I wonder why you unlocked the modem? That should "just work" with a TalkTalk connection as is. Try resetting the modem to factory settings, I imagine you then need to look at the settings on the router side.
ignade
Why the WiFi hub doesn't work as modem? I could use it
The WiFi hub is a modem/router, it was not designed to work as a modem. It can however still be used as a modem & use its routing functions to connect to your router.
