I recently upgraded my broadband to Faster Fibre. Wifi works just fine, but when i connect my PC with Ethernet cable, I don't have access to the internet, despite being connected. This surely isn't a client-sided issue, as I tried two cables and both work just fine with old router. Also all settings seem to be in order.
Hi Rafal7,
I'm sorry to hear this. Have you tried factory resetting the router and then retesting?
Restore your router to factory settings
Yes, I have tried that during conversation with technical support. I've also done every test suggested by an agent. I will be sent a new router to check if this one is faulty.
Hi Rafal7
Did our Faults Team advise that they were sending a replacement router for testing?
Hi Rafal7
Thanks for your reply. Please let us know how the connection compares with this router.
I fixed the problem by manually setting DNS adresses, rather than letting the hardware find them automatically. Ethernet connection works just fine now.
Hi Rafal7
Thanks for keeping us updated. Please let us know if you do experience any further issues.
