New WiFi Hub and connection speed
4 REPLIES 4
martinharris
Good morning all,
Can someone advise how I can update my new Wifi Hub to the latest firmware?
Also, my hub shows a maximum rate of 79284 Kbps and an actual rate of 68767 Kbps.  Is there a way to get the actual rate up to the maximum?
Martin
Divsec
Hi Martin, your post has been flagged for assistance and you should hear during the day, in the meantime please check your community profile and add your landline phone number if necessary.
There is always a drop between maximum and actual, in my case 75000 max and 69000 actual. Line quality, etc. etc. 69000 does all I need, is within spec and rock solid.
Hi Martin, do you have your router connected to the test socket? There's interference on the line test and it's not conclusive as to where.
martinharris
The current 68Mbps speed test is great, I was just curious as to why it doesn't automatically connect at full speed.
Router is into a prefiltered socket, as it always has been.  Please don't make any adjustments that will lower my speed lol
Interference on the line will affect the systems decision on speed. If the speed were higher the likelihood is that the interference would cause problems. Often less is more when it comes to broadband.
