New customer
4 REPLIES 4
I’d like to know how long does it take to install/set up the broad band if I order it today as of 27.03.20
thank you
Hi @Elda2401 in the current environment it is impossible to give an answer. cCould be two weeks, could be 2 months. With engineers moot entering premises could be even longer.
@Divsec I get that. The idea is that if I try to order, it says that they can do it on 8th of April and I want to be sure since my actual provider cannot fix my account.
Hi @Elda2401 not sure Talktalk will know anything about your unfixable fault, if you are not coming from Virgin the lines and exchanges will be likely the same. So you could well find multiple delays.
Hi Elda2401
Does it allow you to place an order on the website?
