New router needs pppoE log in
ANSWERED
37 REPLIES 37
Hello all
This is my last hope to get my router working before I send it back, the problem I am having is with my new Asus Rapture GT-AX11000 its all set up but when I log in it saying disconnected and wrong username and password, I've tried my number @TT.net I've tried leaving it blank but you have to enter the details to continue,  I've phoned TT and they said there is no password or username any ideas ??
Assuming that you are on ADSL, it is true that no username or password are required any more. However, some routers have made these fields mandatory. Just put anything in these fields.
Thank you for your reply.. I've tried countless time in the username and password even left blank still will not connect
Hi stemac123
Add your home number to your Community Profile and I'll check your connection is network enabled and not set to password.
Ok karl I've done that 🙂
Checked your line and the Auth Type is set to Full Network so authentication is taken from the connecting line.  Any user details within the router would be ignored so these details can be set to anything.
Ok thank you Karl, I have tried no details and old passwords and user names in the pppoE log in nothing works still says invalid password or username
As you are using a 3rd party router, is it compatible with TalkTalk's network & is it configured for it? Do you have a TalkTalk router at all you could just temporarily try to see if that connects, just to prove a point? Further information on using a 3rd party router is provided here:-
https://community.talktalk.co.uk/t5/Articles/Set-up-a-non-TalkTalk-router/ta-p/2205383
That is strange, most third party routers will usually just connect.
Try powering all off for 30 minutes then try again as this will clear any stale session.
Ok karl I will post a picture of the error and setting later when I am home, Asus haven't been any help what so ever, they told me to update firmware, I did and it never worked then told me to send it back for refund, I expected abit more help then that lol
Hello again Karl, I've done a network diagnosis test and all well with my router and modem its saying it's a ISP problem, I had a Asus RT AC88U that was working perfectly fine then one morning few weeks ago it was disconnected from the internet and I couldn't get it back online so I thought it was a router problem, that's why I have the latest Asus router,  but now it seem to be not on my end as this router is doing the same, like I said the other Asus was working get for 8 month so something has changed on my internet ??
Have you tried selecting Automatic IP in the WAN > Internet Connection settings?
Followed by Yes > Yes > Yes > Yes > None
Yep I I tried Automatic ip address Ferguson
This is the settings I've just put in and accepted.. still no joy 😞
Hi Stemac have you tried mpoA?
The community is very busy, what took minutes can take hours. Be patient, avoid multiple posts and stay healthy, please.
Hello Divsec not to sure if I have but will give it a try later no opinion for mpoA
I have
Automatic Updates
Static IP
PppoE
Pptp
L2TP
I could be completely wrong with this, so forgive me if I am, but from my recent experience of setting up an Orbi system as my router, I thought that PPoE isn’t used for TalkTalk Fibre and it’s actually a DHCP/IPoE connection.
“The journey home, is never too far...”
Hello Jm I've tried every way and I've done a network diagnosis the router and modem it fine its clearly a talktalk issues, I lost connection on my Asus RT 88U is was working fine for 8 month.. Its like talktalk have turn on or off something on my line..
Hi @stemac123,
I feel your pain. I recently moved to TalkTalk because I wanted to use my own modem and router and it has been a month of hassle trying to get it to work. My Netgear and TP-Link routers both only got DHCP leases for 15 minutes from the exchange and only the TalkTalk router didn’t seem to have a problem. However, modem-only mode seems to be disabled on most TalkTalk routers.
In the end I set the TalkTalk router into DMZ mode and got my Orbi router to deal with the home network. It works fine now but it was a stress getting there.
