No Internet
Everyday for the past 2 weeks my internet has switched off and the light on the hub is flashing amber.
When it does run i only get between 1 and 13 MBPS which is pretty pathetic for so called super fast fibre broadband i pay for, its been like this for 7 months since we moved house
Hi @Steven Heap ,
It would be worth going to the Service Centre to do a test on your phone line, this will indicate if there is currently a fault on your line. You can also access this from the ‘My Account’ site.
If your master phone socket has a test socket then you could also try the router in there, that would then eliminate any of the phone wiring in your home as being a possible cause of the problem.
Hi Steven
  • Name
  • Telephone number
  • Alternative contact number
