No Wi-fi connection status says Wi-fi DISABLED.
8 REPLIES 8
I tried to find a solution chatting to someone from TalkTalk via the facebook page but no joy so am trying here.
My Wi-Fi connection disapeared last week. I can connect to the internet via a cable to my laptop fine but no wi-fi. I checked the status of my router on the hub page and it states wi-fi is disabled I've tried to switch it on but it isn't happening. I have tried a reset and also unplugged my router and restarted it and still not working. Looking at this forum it seems to be a common thing with people being offered a new router to replace the faulty one which mine clearly is. I asked for a new one but the person wanted to try every test even asked me how many bars on my wi-fi so not sure they grasped what I was trying to tell them. They even offered to send a chargeable engineer or for me to upgrade my contract! but I said I just want a router which works but they were reluctant.
As I said there seems to be many posts identical to mine and if anyone could help by sorting me with a replacement router I'd be grateful
Hi seajohnsters
Can I just check if you have also tried a factory reset using the pin hole reset for ten seconds?
If you have tested this and are still experiencing this issue then I can send a replacement router.
Hi Debbie,
Yes this was one of the first things I tried but it didn't do the trick.
Yes thanks a replacement router would be great thanks for your response.
Hi seajohnsters
Hi Debbie
Thank you so much for arranging this. Yes I will definitely update you on how it is. Have a great day.
Hi seajohnsters
Thank you. You too 🙂
New router arrived yesterday and its been working absolutely fine no problems at all.
Thank you so much for your help.
Hi seajohnsters
That's great news, thanks for keeping us updated 🙂
