No internet again!
29 REPLIES 29
No internet since 6am'ish. Restarted router numerous times. Please help!
Hi skoobz
I've completed a line test which has detected a possible fault with the landline service. Do you have a dialtone or are you experiencing any noise on the line?
Is the router currently connected at the test socket?
Hi @OCE_Debbie
Yes the router is in the test socket, it's the only one. I do have a dial tone, but there is also a little noise on the line.
Hi skoobz
Was this noise there previously? Can it be heard when talking on calls?
I hadn't noticed any real noise on calls before no. Just called myself and sounds ok. The noisy line seems intermittent.
Hi skoobz
Would it be possible to remove all equipment from the line including the face plate, router and phone for a short while so I can run another line test in this set up?
Sure, done.
Hi skoobz
Thank you. Just running the test now and I will post back shortly.
Hi skoobz
The line test is now detecting a loop fault. Could you post a photo of your master socket?
Hi skoobz
Is the test socket on the front of the plate? (hanging down)
Yes the front looks like this
@OCE_Debbie
Is it possible to add data to my mobile number untill this is resolved?
Hi skoobz
Apologies for the confusion, is there a test socket on the 2nd part of the face plate (behind your hand)
Yes I believe so
Hi skoobz
Ok, is the no sync fault still present if you connect the filter and router at the middle part of the socket (faceplate removed) I will then raise this fault for investigation.
@OCE_Debbie
No, it still doesn't work just plugged into the other socket behind the face plate.
So, is it possible to add data to my mobile until this is resolved please?
Thanks for your help so far.
Hi skoobz
I have raised this over to Openreach to be investigated by a line engineer and we should receive further updates within the next 48hrs.
Apologies, we would be unable to arrange this. I would suggest contacting our Customer Service Team to discuss this further.
Thanks @OCE_Debbie
So, do I now just wait? As there is no land line/dial tone now will I be contacted on my mobile? Or will I receive updates through here?
Hi skoobz,
Your should receive updates on your mobile, if you don't hear anything within 48 hours can you bump the thread and we'll check for updates
