This morning my internet is not working. The router showed a solid orange light. I turned the router off and back on and it alternated from flashing orange to flashing white before stopping on a solid orange light.
Could you please check the line and advise how to fix this immediately.
Hi emma,
I'm sorry to hear this. I've run a test on the line which hasn't detected a fault and the connection looks stable for 2 days. Is your connection ok at the moment?
Hi.
Thanks for getting back to me. Yes the internet is working now and has been for a few days. It seems there was a fault in the area which has been sorted.
Emma
Hi Emma
Thanks for your reply 🙂
