Not getting guaranteed broadband speed and missing posts!
Hi Sebsan,
Ok thanks for the update and please let us know how the speeds compare over the next 24-48hrs.
Hi Michelle
sorry about the delay in responding, for some reason I’ve had to re register on this site, really don’t know what’s happened here. (now sebsan2).
Received the router and have conducted speed tests the results are erratic to say the least
13th feb
lenovo p2- 32.2/18.6
ipad1- 30.7/14.6
ipad2- 12.9/18.5
iphone6- 26.7/18.3
14th feb
lenovo p2- 46.3/18.1
ipad1- 34.9/14.3
ipad2- 37.1/17.5
iphone6- 3/6.2/19.2
ive also conducted a few stand alone tests with the Lenovo p2 and have reached mid 60’ on a couple of occasions but only on this device. All other devices are only reaching the figures highlighted above and all devices are still not achieving the guaranteed minimum speed.
can you please advise
many thx
sebsan2
Hi Sebsan2,
  • Name
  • Telephone number
  • Alternative contact number
All done, many thx
sebsan2
Hi Sebsan2,
Thank you. I've run a test on the line which hasn't detected a fault and the sync speed looks consistent. Could I just confirm, were all the recent speed tests completed wireless?
Hi Michelle
yes, all wireless.
many thx
sebsan2
Hi Sebsan2,
Thanks for confirming. Have you tried separating the SSID's on this router?
Split your router's SSID (wireless network name)
Hi michelle
tried this and I can only get as far as ‘Manage advance settings’. After this no pop up box appears to continue nor do I see ‘wifi Configuration’. It leads me to ‘welcome to talktalk WiFi hub’ page.
interestingly two of my devices have automatically defaulted to 2.4gz (both iPads) and two to 5gz (iPhone 6 and Amazon Alexa). Although my android phone (Lenovo p2) is connected via WiFi, it doesn’t appear at all!
so as it stands, I can’t progress any further. Would it be better for someone to call me and talk me through it?
kind regards
sebsan2
I've changed the wifi SSID for you to separate the channels, the 2,4Ghz chanel now ends with a '2' and the 5Ghz channel ends with a '5'.
The password is the same.  Connect to each of the 2 channels in turn and see if one is better.
Thx Mark
Yes I can see that now and I can also see that all devices are stored under 5ghz. Just can't see how to move any over them over to2.4ghz to try them out.
Also when 5ghz section is selected it states channel 44 on the 2.4ghz section the channel selection states auto. Does this affect anything?
Thx in advance for your help
Sebsan2
Sebsan
Sorry, I meant Karl
Apologies
Sebsan
Hi Karl
Forget that, I’ve sussed it.
ive run speed tests on both 5ghz and 2.4ghz
2.4ghz is definitely slower than the 5. We’ve run tests about 3 meters from the hub.
ipad 1 33.8/16.3 (5ghz) - 33.2/16.6 (2.4)
ipad 2 31.3/16.7 (5ghz) - 28.1/17.6 (2.4)
iPhone 6 41.2/18.7 (5ghz). - 30.1/18.6 (2.4)
So as you can see, no improvement at all I’m afraid
could you kindly advise
thax so much
sebsan2
Hi Sebsan2,
Ok thanks for trying this. Could I just confirm, are the speeds ok if you run the speed test wired? I'm just trying to confirm if this is solely related to the wireless connection as we can offer more advice on this.
Hi Michelle
I'm sorry but we don't have any device that we can wire to the router. All our devices are wireless and all the speed test results given previously have been conducted wirelessly.
Hope this helps
Sebsan2
Sebsan
Hi Sebsan,
Approximately how far from the router is the device that you're running the speed tests on? Does it make any difference to the speed if you move to within a meter of the router?
Is your router situated close to other wireless or electrical devices that could be causing interference?
Hi chris
In a word, no. It makes no difference. Previous speed tests were from approx 3 metres. Just taken one with my iPad sat next to the router 30.0/13.7 so no difference whatsoever
Nearest device to the router is a tv which is 3-4 metres away and not even switched on.
we’re getting a bit frustrated tbh as we’ve experienced this lack of performance from day one and we’re still so far away from achieving the guaranteed minimum speed that you’ve pledged
can we please resolve this
thank you
sebsan2
OK thanks for the information, just to confirm, you don't have a cordless phone near your router? (I had wireless connectivity issues with my router and found that it was being caused by a nearby wireless doorbell chime)
No Chris
the cordless phone is in a different part of the property separated by doors and walls.
To recap, we can connect wirelessly to our devices but the speed is so slow, certainly no way near achieving the guaranteed minimum speed pledged.
appreciate your help in resolving this
thx
sebsan2
Hi Sebsan2,
Thanks for confirming this. I've re-checked all the connection stats and the firmware and everything still looks ok so I'm not sure what is limiting the current wireless speeds on your different devices, especially as the lenovo laptop (mentioned in one of your earlier posts) has faster wireless speeds.
@KeithFrench - Would you be able to offer any more advice in regards to the wireless speeds?
Hi @Sebsan
Michelle has asked me to help you with your wireless issues. Where a thread is very long like this, I simply do not have the time to read through it all, so you may have to bear with me. Judging by one of your posts though, I assume you have the Sagemcom Wi-Fi hub?
The TalkTalk Wi-Fi Hub is a dual-band router & offers both the older 2.4GHz & the newer 5GHz Wi-Fi bands. The problem is these are two different networks (SSIDs), but they share the same name, so you can't tell which one you are connected to. Log into the router (http://192.168.1.1) and enter a username of "admin" and use the unique router password (see the label on the rear of the router at the top).
Go to:-
Dashboard > See Wi-Fi Settings > Manage Advanced Settings > Wi-Fi 5Ghz gear icon > Basic
Append "5G" to the end of the network name of the "SSID" field. Then click "Apply".
This will not fix your issues, but it will make it much easier to identify the band you are connected to. This way you will know which band is causing your problems.
Having said that, there is another approach which can be better, which is to use Band Steering. This will automatically move any 5G compatible device connected to the 2.4G band to the 5GHz band. To use this facility on the Wi-Fi Hub, leave both network names identical.
You may then wonder what was really the point of this if it won't solve the problem? This is because the whole topic is too complex to be dealt with in one post. The next stage involves sending out a guide to you to help you get me some important diagnostic results, so as I can analyse them for you and recommend changes to your router configuration to solve them.
