I have my WiFi hub set up and have access via all devices except for one android phone, I also have a repeater set up and can access all areas on everything except with this phone, I have rebooted everything several times and still I get no internet on this handset
Try reset network settings. Usually under Reset WiFi, mobile & Bluetooth.
Yes on handset.
Try find under settings Reset WiFi or Reset Networks
On my one phone:
Settings -> System -> Advanced -> Reset Options -> Reset WiFi, Mobile & Bluetooth
On another phone:
Settings -> About Phone -> Reset -> Reset Network Settings
When open Settings, try enter RESET into search window.
If not helps Reset networks - backup all data and full phone reset.
"i dont see why i have to perform a hard reset on my phone to get it to hook up to my hub, i have many android devices connected without issue"
I think the suggestion might be that as it's just one phone that can't connect to the internet it suggests its related to the phone not the router.
I agree a full reset is a bit drastic though.
Have you tried forgetting the network on your phone and then re-joining the network again?
Or try Google's DNS servers on your android phone. I had to do that on a PS4 and an iphone that would get the wifi connection but not get to the internet.
Fritz
Hi loady,
Could you try switching the router off for a full 30 minutes and then retest this again please.
Hi loady,
I'm sorry to hear this. What is the make and model of the previous router? Do you still have this router to test with?
Hi loady,
We'll then look into this further. Please do not post this information on this thread Once you've updated your profile please post in your topic to confirm it's updated.
