Hello Nerds and Nerdlings,
Online Gaming currently makes me sad, i'm hoping this screenshot provides possible insight into the issues i'm having. (rubberbanding, no hit registration, warping, etc.)
Any help, advice or technical tips are most welcome.
The target ip address is currently the most used server i connect to when playing BattleField 5.
Thank you for reading 🙂
Hi Alex Z,
The line test is clear and the connection stats also look ok. Are you connected wired or wireless?
Hi Michelle,
I'm connected via a LAN cable to the router.
(i also did this test on my laptop which is running windows 10 via Wireless, and the results are still the same, sadly.)
Hi Michelle,
I'm not sure if this screen shot is helpful in anyway, but this route and these hops to www.vodafone.de are perfect. Perfect amount of MOS, Jitter, packetloss and very acceptable error count too.
If only some how i could take a similar route to the game servers, although this may be impossible! ha. 🙂
Hi Alex Z,
Ok thanks. Is it only this particular game that is experiencing the issue? Does it happen at all times or at certain times of the day? Has this previously worked ok?
Could you run a wired ping and trace route the next time this happen and post the results into the thread please.
Hi Michelle,
No this particular issue always arises when i travel through ae66.edge6.London1.Level3.net - 212.187.165.173 - no matter if it's a game server, webpage or FTP. It's evil!
It always happens and it has never worked correctly. 100% of the time.
As requested here are x3 of each, Ping and Route test results.
( I guess my PingPlotter screenshots are not acceptable 😄 )
Trace 1
Trace 2
Trace 3
Ping 1
Ping 2
Ping 3
Hi Alex Z,
I'm sorry for the delay. Could you post the results into the thread as plain text so that I can pass this over to our Network Team for further investigation as I can't copy the image. Could I also just confirm if the overall connection is also ok such as browsing/streaming/etc? It's only still gaming which is affected? Is the speed also ok if you run a speed test at the same time?
Hi Michelle,
I hope you had a nice weekend and i thank you for your on going perseverance into my current issue, it's greatly appreciated!
My overall connection seems perfect, browsing webpages or streaming from sites like YouTube, Netflix, Amazon Prime etc are fine. I experience no problems with anything that has a chance to buffer the data.
Anything Real-Time like Online gaming, VoIP or even some Live Video Streaming does breakdown and suffer IF i travel through certain hops like the one i'm currently experiencing with - ae66.edge6.London1.Level3.net - 212.187.165.173 - ( hop 6 )
I'm not sure if the hops aferwards are directly related or they are also an isolated problem?
- 4.69.167.228 - ( hop 7 and 8 )
I've just noticed my route travels through this particular hop twice, i have never ever seen that before.
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Windows\system32>tracert 159.153.38.58
Tracing route to bfvprapp-10.ea.com [159.153.38.58]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms ttrouter [192.168.1.1]
2 * * * Request timed out.
3 19 ms 20 ms 20 ms host-78-151-238-69.as13285.net [78.151.238.69]
4 20 ms 19 ms 24 ms host-78-151-238-64.as13285.net [78.151.238.64]
5 20 ms 20 ms 19 ms host-78-144-14-108.as13285.net [78.144.14.108]
6 * * * Request timed out.
7 * * 21 ms 4.69.167.228
8 * 20 ms 21 ms 4.69.167.228
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 31 ms 31 ms 31 ms 159.153.72.14
13 31 ms 31 ms 31 ms bfvprapp-10.ea.com [159.153.38.58]
Trace complete.
C:\Windows\system32>ping 159.153.38.58
Pinging 159.153.38.58 with 32 bytes of data:
Reply from 159.153.38.58: bytes=32 time=31ms TTL=50
Reply from 159.153.38.58: bytes=32 time=30ms TTL=50
Ping statistics for 159.153.38.58:
Minimum = 30ms, Maximum = 31ms, Average = 30ms
Thanks again for your time and effort!
Alex.
Just a little more info, i copied and pasted some data from my Ping Plotter results,
Target Name: 159.153.38.58
IP: 159.153.38.58
Date/Time: 28/05/2019 17:08:34 - 28/05/2019 17:18:34
Hop Sent PL% Min Max Avg Host Name / [IP]
1 601 0 0.21 3.53 0.57 ttrouter [192.168.1.1]
2 598 100 0 0 0 [-]
3 601 0 19.71 73.53 20.69 host-78-151-238-69.as13285.net [78.151.238.69]
4 601 0 19.56 53.81 20.72 host-78-151-238-64.as13285.net [78.151.238.64]
5 601 0 19.72 52.69 20.87 host-78-144-14-108.as13285.net [78.144.14.108]
6 598 99 516.16 2348.20 1532.55 ae66.edge6.London1.Level3.net [212.187.165.173]
7 598 71 20.00 22.88 21.14 4.69.167.228 [4.69.167.228]
8 598 72 20.52 22.59 21.15 4.69.167.228 [4.69.167.228]
9 598 100 0 0 0 [-]
10 598 100 0 0 0 [-]
11 598 100 0 0 0 [-]
12 601 0 31.09 132.88 33.70 159.153.72.14 [159.153.72.14]
13 601 0 30.00 34.75 31.49 159.153.38.58 [159.153.38.58]
Here on hop 6 you can see some shocking ping data, not to mention the overall packetloss between hop 6,7 and 8. A total of 242%.
Hi Alex Z,
Thanks, the 2nd hop doesn't look right. Just to confirm, have you made any changes to any settings in the router? Are you using a TalkTalk router?
Hi Michelle,
I was forced to do a hard reset (small little pin hole button) on the router itself after it stopped responding a few weeks ago, but i am indeed using the TALK TALK router. Do you think i may need a replacement?
thanks,
Alex.
Hi Arne, Hi Michelle
This is my trace route to vodafone.de. I have no problems at all with these hops, everything is perfect. MOS (Mean opinion score) is perfect, a total of 4.4. Jitter is also perfect, a total of 1. Packetloss is also fine, a total of 0%. ( in my experience it's usually fine to ignore packetloss that doesn't fluctuate away from either 0% or 100% )
These are the things i look for when checking the quality of a route as they are absolutely vital for a good online gaming experience.
Target Name: <a href="http://www.vodafone.de" target="_blank">www.vodafone.de</a>
IP: 139.7.147.41
Date/Time: 05/29/2019 14:34:29 - 05/29/2019 14:44:29
1 35 0 0.51 0.70 0.56 ttrouter [192.168.1.1]
2 34 100 0 0 0 [-]
3 35 0 19.81 32.77 20.53 host-78-151-238-69.as13285.net [78.151.238.69]
4 35 0 20.01 27.92 20.47 host-78-151-238-68.as13285.net [78.151.238.68]
5 35 0 25.57 37.64 28.71 host-78-144-14-116.as13285.net [78.144.14.116]
6 35 0 25.60 31.91 26.59 host-78-144-14-43.as13285.net [78.144.14.43]
7 35 0 20.21 38.97 22.32 host-78-144-14-2.as13285.net [78.144.14.2]
8 35 0 24.96 43.97 25.81 host-78-144-11-235.as13285.net [78.144.11.235]
9 35 0 26.17 26.85 26.53 AMDGW2.arcor-ip.net [80.249.208.123]
10 35 0 34.29 35.95 35.01 92.79.215.241 [92.79.215.241]
11 35 0 34.29 35.03 34.71 92.79.230.14 [92.79.230.14]
12 35 0 33.94 38.91 34.58 139.7.148.84 [139.7.148.84]
13 34 100 0 0 0 [-]
14 34 100 0 0 0 [-]
15 35 0 34.33 38.59 34.90 <a href="http://www.vodafone.de" target="_blank">www.vodafone.de</a> [139.7.147.41]
Based on these results and my understanding, my hardware is working perfectly. But if a new Talk Talk router is needed for whatever reason then i'm happy to oblige.
Thanks again for your time and efforts into my issue.
Alex
Hi Alex Z,
Thanks, it would be worth trying the replacement router and if there is no improvement then we can pass this straight over for investigation.
