PS4 best settings for lowest latency
4 REPLIES 4
Chat Champion
Hi can anyone tell me the best router settings for playing the PS4 online. Hard wired nothing else on the network, thx.
Donny
You could try changing the default DNS on the ps4 to google ones.  these are 8.8.8.8 and 8.8.4.4  I can't tell you how to do it on a ps4 as I have an xbox one, but its not that hard.  This guide might help?
https://ps4dns.com/change-dns-ps4/
Chat Champion
Thx bro i’ll Give that a whirl. My router is tplink w9970, the game I play is pes2020. When your using Xbox, do you mostly get good connection?
Donny
I actually havent gamed on the xbox since i moved to TT. I have gamed on the pc and had no issues. My suggestion about changing DNS server addresses is that the TT ones could be over loaded with the amount of extra traffic with the lockdown.
Also, is your ps4 wired or wireless?
Chat Champion
Sorry mate, ah I see you haven’t tried Xbox TT klm8
Donny
