Periodic slowness fixed by restarting router
13 REPLIES 13
Hi, I have had this issue for years, but it suddenly seems to have got a lot worse.
Basically, I periodically have to reboot my router to "fix" slowness issues.
This used to happen maybe once a week, although it's never been regular times. Recently it's got worse and I've had to restart the router twice today.
See below images for a before and after:
Yes, I have checked the usual things and been through all the usual checklists for slowness. Right now, it's just me at home and there is only one device connected.
I've had the same router for years now - any chance an upgrade would fix this annoying issue?
Let me know what information you need...
Oliver Clare, TalkTalk Customer
I assume that this is on wireless connections, do you have any wired ones to compare this with?
Thanks for your reply Keith. You're right that this example was on a wireless connection using the Google Speed test. However, I haven't noticed any difference when running these tests on wired or wireless over the last few years, via Google or Ookla or Speedtest.net. So now I generally just stick to whichever test is the easiest to do at that time (e.g. whether on PC or phone when everything goes s l o w).
I am 100% convinced the issue is with the router itself. Trust me when I say I have tried all the usual steps several times in the last few years. I think there's even a community post here by me from the original issue. When it became clear that rebooting the router "solves" the problem (in the short-med term), that was enough for me. Now it's getting worse, I'm seeking more answers.
Thanks for your time.
Due to that information, I have asked one of TalkTalk's OCEs to pick your thread up and investigate it for you.
Thanks! Yeah, no massive rush. It's been an issue for a while so a couple of days more is nothing 😄
Hi LordScree,
Just to confirm, are you currently using the HG633 router?
Yep, that's the one 🙂
Hi LordScree,
Ok thanks for confirming. Would you like us to send a 3782 router for testing purposes?
Sure! Happy to try a new router. Thanks!
A new router is on the way for testing.
This should arrive in the next 24-48 working hours.
You are awesome! Thanks Karl! Fingers crossed this fixes the issue. I'll report back on this thread.
I thought I should add an update.
I've had the new router for a week now. The first three days, I was getting some really poor speeds. However, I was expecting this, so I left the router untouched.
I am pleased to say that, from yesterday, the download speed seems to have levelled out at a fairly consistent 28Mb/s. I will continue to test regularly over the next week or so, but I have not had a recurrence of the very slow speeds seen with the previous router (that were temporarily resolved with a reboot). At present, it seems that the new router is at least more stable than the old.
However, my contract is for 36Mb/s - and I did used to get 36Mb/s using the old router. I seem to have lost 8Mb/s somewhere along the line. Does anyone have any ideas on what could be causing this @OCE_Karl @OCE_Michelle ?
Hi LordScree
If the connection remains stable then the speed should start to increase. I've checked the connection stats and your line is in sync at 30mb.
Is the router at the test socket?
