Playstation dropping mid game
3 REPLIES 3
Grimshaw24
i have exact same issue as below link post, except my connection is 5GZ wifi. But i have identified the same issue as i have tested with other 5GZ connections from sim wifi hubs and phone hotspot and have zero issues. Router is basically in same room as playstation and only on COD so far ive noticed
https://community.talktalk.co.uk/t5/Broadband/Repeatedly-losing-connection-when-online-gaming/td-p/2...
OCE_Karl
Hi Grimshaw24
Can you add the home phone number to your 'Community Profile' so we can check your line.
Grimshaw24
@OCE_Karl Done!
OCE_Michelle
Hi Grimshaw24,
Thank you. I've run a test on the line which hasn't detected a fault, the router has the latest version of firmware and the connection stats look good. Can I just confirm, do you mean that all other wireless devices are stable and it is just the playstation which is dropping the wireless connection?
