Please Increase Sync Speed Profile
37 REPLIES 37
pentham
xDSl
 StatusConnection TimeLink StatusStandardLine EncodingLink Encapsulation
Line 1
UP
2d 06h25m16s
UP
VDSL2 (G_993_2_ANNEX_ B)
DMT
ATM (G_992_3_ANNEX_ K_ATM)
Line 1
DownstreamUpstream
299935735
372085735
0.006.00
22.400.00
11.203.40
Hi pentham,
How many telephone sockets do you have? What other devices do you have connected in addition to your router?
Does your master socket have a Test Socket?
Are you experiencing any problems with your telephone service such as noise on the line?
pentham
Hi Chris
Only 1 master socket which does not have a test port.
Filter, router and landline phone connected.
No problem or noise on phone line.
Hi pentham
I've completed a line test which has detected a possible fault.
Would it be possible to post a photo of your master socket?
pentham
pentham
Hi pentham
This socket should have a test socket under the face plate, would it be possible to connect the router and phone at the test socket using a microfilter so I can run another line test?
pentham
Hi Debbie
That's done.
Hi pentham
Thank you. I've completed a further line test which is still showing a possible fault.
I have raised this over to our Network Team for investigation. Please can you post back on this thread in 24hrs and we can check for further updates.
pentham
Hi Debbie
Thanks for your help  I will check back for updates
Hi pentham
I have requested an update on this fault from our Network Team and I will post back on this thread as soon as I receive further information.
Hi pentham
The next step will be to arrange a BT Openreach engineer visit.
pentham
Further to Openreach engineer visit. Did some tests, fitted new master socket and disconnected an extension cable. Line is working to optimum, but download sync speed is stlll below guaranteed minimum
Stats...
xDSl
Line 1
UP
01h29m19s
UP
DMT
Line 1
DownstreamUpstream
334159629
334159629
0.006.00
31.900.00
11.004.80
Hi pentham
Did the engineer reset DLM?
pentham
Hi Debbie
Not sure about DLM reset.
But I am 350mtrs from FTTC
Hi pentham
The line test is now clear so DLM should start to increase the sync speed.
Please can you leave the router switched on without rebooting and we can check the connection stats in 48hrs to see if DLM has increased the speed?
pentham
Hi Debbie
Yes, I will leave router connected for 48hrs
Thanks for your fast response
OK thanks, if you bump the thread on Friday we can check how you're getting on 🙂
pentham
Speed is 32.5 down    5.9 up
xDSl
Line 1
UP
06h05m01s
UP
DMT
Line 1
DownstreamUpstream
325485949
373305949
0.006.00
22.400.00
11.203.10
Hi pentham,
Thanks for the update, I've passed this back to our network, if you don't hear anything later today or over the weekend can you bump the thread again on Monday
