Plume and other Mesh systems?
 Hi @OCE_Debbie,
Yes, if you look at the previous posts with screenshots of the stats you can see that the actual is always higher than the maximum.
These are the current router stats:
“The journey home, is never too far...”
Hi jmclevine
I think this may be the router misreporting.
Hi @OCE_Debbie,
I tried it with a BT Openreach modem and the actual was higher than the maximum with that too.
Hi jmclevine
Apologies for the delay.
Your sync speed looks good. I'm not sure why the routers are reporting this figure.
Is your connection performing ok?
