Poor broadband signal
ANSWERED
16 REPLIES 16
swain-16
All week my fibre broadband signal has been really poor.  Its not my PC as I have a TP-LINK 600mbps booster, and the signal is the same on my phones and tablets wherever we are in the house - even sitting next to the router.  I work from home through the internet - this is totally not acceptable.  I have read other complaints and tried all the remedies that have been offered but nothing is working. Very disgruntled and will stop paying if not resolved!
Hi swain-16
swain-16
Unbelievable!!  I have just been speaking to Frederick on the account chat app. He said that we might need our Wifi channel to be changed.  I remembered this was a problem last time and when you changed the channel everything was good again until the next time.  I then made a flippant remark asking why do you keep changing our channel - probably so you can fit even more people into an already overflowing exchange and his reply was "Yes, that's a big possibility!"  So that confirms what I have thought all along - that TalkTalk sign people up even if they don't have the resources to provide them with a good service.  My oh my! I should have gone to BT!
Hi swain-16
Apologies, wireless signal is not related to the exchange.
Wifi is a localised signal that goes from your router to your device, this is not related to the exchange. If you have interference on your wifi then this can be caused by other devices around you.
If your neighbour uses the same channel as you then this can cause interference.
swain-16
Thank you Debbie - not what he said though.
So, if it comes up as being slow on a broadband speed test then it is the line from the exchange to the house - which is what we were talking about.  Everything in the house is okay.  Just don't see how we can go from  16mpbs when it was installed a few months ago down to 4mpbs as has just been recorded but only showing 2 bars at best on all our devices.  Our standard broadband was abysmal which is why we changed to fibre after much persuasion from the talktalk assistant but after a few months, as always, its still no better.  Talktalk are not alone in their poor service - I just don't know why all of you ISPs can't get it right and make everyone happy.
swain-16
OK so, it had just dropped completely for a while so I wasn't even able to respond.  I am trying to print something on a wifi printer which I am trying for the third time now.  When I look at my network properties and the channels available, I do see another secured TalkTalk resource on it which isn't mine.  That presumably is the neighbour that is on my channel.  How does that get resolved and why can't it be done without me having to keep calling or hanging on my mobile while loads of checks are done please?  I don't have the time for this and when you pay for a service, you expect to get it.
So frustrated now - this is costing me money because I can't work!
Hi swain-16
Have you tested different wireless channels to see how the connection compares?
Changing your wireless channel
swain-16
Thank you Debbie - at last I get somewhere - didn't even know I could do this after all the hours I spend online chat and the phone!.  Sadly though, my internet is not staying live long enough for me to do it - trying to do it dribs and drabs. I can't do it at all on my PC so am having to use my tablet on and off!  This is horrendous!  Channel 6 didn't work at all so I changed to channel 11.  It is stronger on my tablet and phone but still only two bars on my PC, but at least I am making progress.  Many thanks
Hi swain-16
Do you have any devices connected wired?
@KeithFrench provides really good advice in regards to improving wireless performance.
Solution
Hi @swain-16
Debbie has asked me to help you with your wireless issues. Slow speed, intermittent dropouts, breaks in the signal, or no signal on some or all devices, might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, and neither do they get any visibility of this either> This is mainly a by-product of the popularity of Wi-Fi.
If you have the HG633, HG635, or DSL-3782 they are dual-band routers & offer both the older 2.4GHz & the newer 5GHz Wi-Fi bands. The problem is these are two different networks (SSIDs), but they share the same name, so you can't tell which one you are connected to. Log into the router (http://192.168.1.1) and enter a username of "admin" and if the HG635 a password of "admin" as well, or if the HG633 or the DSL-3782, use the unique router password (see the label on the rear of the router at the top).
HG633/635 go to:-
"Customise my wireless network"
Append "5G" to the end of the network name of the "Wireless 5 GHz SSID" field. Then click "Save".
DSL-3782 go to:-
Settings > Wireless (Wi-Fi)
Append "5G" to the end of the network name of the 5 GHz "SSID" field. Then click "Save".
This will not fix your issues, but it will make it much easier to identify the band you are connected to. This way you will know which band is causing your problems.
You may then wonder what was really the point of this if it won't solve the problem? This is because the whole topic is too complex to be dealt with in one post. The next stage involves sending out a guide to you to help you get me some important diagnostic results, so as I can analyse them for you and recommend changes to your router configuration to solve them.
 Hi swain-16
Have you had a look at Keith's post?
nogoodmrfish
Was this a solution to the problem because I’m wondering if it can help on my thread as well possibly?
Hi nogoodmrfish
You can apply Keith's advice to your wifi issues and see if they help.
haitch9
I have some of these problems with slowness, intermittent signal etc and can imagine it might be due to popularity of wifi as there are plenty of new ones around here.
So I followed the instructions:
'Log into the router (http://192.168.1.1) and enter a username of "admin" and if the HG635 a password of "admin" as well'
i was confused by the 'password of admin as well because i do not have one - i used the password on the router and that did not work twice and then i stopped, so how do i get the right password for my HG635?
thanks!
Hi @haitch9
I can only quote the default values, if yours have been changed you might have to pin reset your router. The username may well be case sensitive as it is on the HG633 where it is admin not Admin.
However, if you want help, you cannot use someone else's thread.
To get help, you must start your own thread. To create your own thread, go to the main page for the board in question & click the "Start a topic" button.
TalkTalk insists on one thread per problem per customer. Please note, TalkTalk makes the rules, not me.
JP 787
I have no broadband service. I work from home and this is happening on a regular occurrence. If this is not sorted I will inform of I'm and cancel my contract as you aren't providing a service at the moment
Hi @JP 787
Please can you create a new thread, we can then look into this further.
