Poor download speeds
Newbie
Joined TalkTalk 15 September. Download speeds around 23 not promised 42 with speed boost. How can I get speeds improved? Thanks
Hi @Maycov ,
Are you doing the speed test from a wired or wireless device, it is always best to do it from a wired device to get accurate results.
There should be a section about the speed to your router on the Service Centre, does this indicate your are getting the speeds you should be, or does this also show your speeds are much slower than expected.
Then they will hopefully be able to respond to this post within a day or two.
Hi Maycov
Can you please add your home phone number or Account number to your Community Profile.
We will not attempt to call you, this is so we can locate your account and run tests on your line if required. We will then reply via this Community.
If unsure of your phone number, and if your line is working simply dial 17070 from your land line phone and this will confirm the number for you. Alternatively these details can be found within My Account online or may be on the heading of any paperwork you have received.
