Problem with Windows 10 / Chrome / HG633 / Cisco AnyConnect VPN - Establishing secure connection...
ANSWERED
11 REPLIES 11
Hi there,
I use the HG633 router to access fibre broadband. My work Win10 PC requires me to use the Cisco AnyConnect VPN. To access wifi with any stability I use DuckDNS.
Over the last few months, I have found that websites increasingly show the 'Establishing secure connection...' message in the bottom left of the screen and eventually drop after a minute or two. Cutting and reconnecting to the router (requires re-entry of VPN password) fixes the problem briefly but it quickly comes back.
I should also mention that the settings on my work PC are heavily locked down so solutions involving DOS commands etc. are unlikely to work.
Other devices (Smartphones, Netflix etc) don't seem to be affected.
Any help greatly appreciated.
Solution
DuckDNS is a DDNS provider, this will have no impact on your problem. Is the HG633 running the latest firmware (v2.00)?
Yes, HG633 is on V2.00t
Is this locked down laptop a work machine?
On V2 firmware, the HG633 has no known probles with VPNs. Does the IP address handed out to your pc from your work's VPN server conflict with the 192.168.1.0 IP network?
Thanks Keith, it is a work PC. How would I find out if there's a conflict?
Ask your IT department. Daft question, I assume that the VPN client is allowed through your pcs firewall in an outbound direction?
Thanks Keith. I don't have the issue on other WiFi networks 🤷‍♂️
All I can do then is pass it over to TalkTalk in case your router is faulty or something.
Thanks Keith, no issues with other devices. It's a weird one! Thanks very much for taking the time to help, much appreciated.
Hi nreed,
I'm sorry to hear this. The HG633 (v2.00) should work fine with VPN. Just to confirm, have you tried factory resetting the router and then retesting this again?
Thanks Michelle. I had not tried this but have done so this morning. It has not solved the issue unfortunately.
Hi nreed
I can send another router to test with, would you like me to arrange this?
