Over the past year my broadband speed has slowly dropped from 33.2 Mbps to currently 10.9 Mbps. I have had a chat with an Openreach engineer and he has advised me that it's probably due to the resistance in my internal phone lines as the router is a very long way away from the master socket. I have plugged the router into the master socket now for about a day but my speed hasn't increased. Do I need to request an exchange reset to re-optimize my broadband connection?
If so how do I go about it?
I have tried talk via chat but they just wanted to send me a new router.
Best regards,
Jon.
If your speeds were over 30 meg at the outset then I presume you have a fibre service. In which case the line is automatically controlled by Openreach DLM and cannot be reset. Connecting at the master socket is good, connecting at the test socket would be even better as that will disable your internal wiring, try that and see if there is any improvement over the weekend.
Hi Jon1234,
How have you found the connection and speed since your last post?
Hi Jon
Would it be possible to connect the router directly at the test socket for 48hrs without rebooting the router? We can then check the connection stats to see if DLM starts to increase the speed in this set up.
Hi Debbie,
I forgot to mention that I have taken several screen grabs of the "Broadband Information" from the router over the last 3 days, if it will help?
Jon.
Hi Jon1234,
Thanks for confirming this. The line test hasn't detected a fault. Is the voice service ok with no noise on the line? Do you have an alternative router that you can test with?
Hi Michelle,
Voice service ok and I don't have an alternative router to test with.
Jon.
I've a router on the way to you so a hardware issue can be ruled out.
Thanks Karl,
I will post again once the router has arrived.
Jon.
New router plugged into test socket and switched on.
Router shows the following...
Current speed - Download 11.4 Mbps - Upload 10.0 Mbps
Hardware Version - FAST5364 3.00
Software Version - SG4K10001400t
Standard - VDSL2 (G_993_2_ANNEX_ B)
Line Encoding - DMT
Link encapsulation - ATM (G_992_3_ANNEX_ K_ATM)
Downstream Upstream
Actual Rate [Kbps]11397 9996
Maximum Rate [Kbps] 65522 9996
Noise Margin [dB] 0.00 6.00
Attenuation [dB] 18.40 0.00
Power [dBm] 11.10 5.90
I'm also detecting a bridgetap on the line, so this will need an engineer.
I'll drop you a PM with the info required.
Hi Jon1234
Thanks for the Private Message.
Please can you also provide your availability for an engineer visit AM and PM?
Hi OCE_Debbie,
The availability regarding AM or PM depends on the date that the engineer would be visiting as I will have to arrange time off work.
Jon.
Hi Jon
If you could provide a couple of dates that would work for you then I can ask our Network Team if they are available and then post to confirm once the visit has been arranged.
Hi Debbie,
Please just book me the next available visit and I will sort something out.
The only thing is I am away between the 24/08/19 to the 01/09/19.
Jon.
Hi Jon
I've passed your availability for an engineer visit over to our Network Team and I will post back on this thread to confirm the date and time of this visit.
