Reconnect but no log entry?
5 REPLIES 5
CraigMcK27
I've had a reconnect this morning, but there is no log entry, I was hoping to see something in there to suggest why it felt the need to reconnect.
Should there have been a log entry for a reconnect?
I'm not showing any physical reconnects from here.
A drop may not always be logged if it was due to a DLM change, WiFi channel change or Bandswitching from our optimisation system.
CraigMcK27
Thanks for that.
Its showing a connection uptime of 6hrs so I’m sure it was off.  I’ll keep an eye on it
PS WiFi is off so should not be that
Any idea when v2800t will be released. I would like to get my DynDNS setup again with the new router.
There was a change to DLM at around 07:00 this morning so this could explain the drop.
V2800t is about to enter public trials in the next week or two so a release should not be much longer.
CraigMcK27
s for the update.
Happy to do some testing on the V2800t if it gets me sorted with DynDNS?
As soon as the FW is available we'll let you know.
