Remote desktop from Internet
6 REPLIES 6
phildick
Can you enable Remote Desktop from the internet on my account.  I have the Hub router and believe that scam protection needs to be disabled.
Not only does that need to be disabled, but you will also need to set up the required port forwarding on the router & allow it through the PC's firewall. I'll get an OCE to disabled the scam protection & if you need help with the other things I have mentioned, let me know.
phildick
Hi Keith,
Thanks for your help.
The hub has upnp IGD enabled which forwards ports automatically I believe.
Do you know about this?
Yes I do & I expect that you will find that method very unreliable.
phildick
Ok, thanks for the info.
phildick
Hi OCE's
Can you disable the scam protection for me?
OCE_Debbie
Hi phildick
I'm just sending you a Private Message to confirm some details.
