Router / Hub position
ANSWERED
Super Duper Contributor
IMG_20200123_131026.jpgHi where would you suggest for the Hub
On the window cill again (thats where my old router sat but got hot in the summer)
Or on my tv unit?
Also how do i turn the light off?
Problem Solver
Solution
Download Wifi Analyser by Farproc (I think I spelt it correctly) onto your phone and see what location gives you best coverage.
Probably the window cill in your case although ideally you want it as central as possibe in your home, not on the floor and away from metal objects which includes tv, foil lined insulation (maybe in the walls or floor) and mirrors..
Fritz
Loving this wifi analyser tons better than the one i used to use
Thank you
