Router WiFi hub disconnect and reconnects DNS failures
8 REPLIES 8
akeel
Hi guys,
Hope someone can help. My router is dropping connection multiple times during the day. By the time I log in to the routor to check it's reconnected. Some times it's every few minutes and some time every hour or so.
It's only started happening over last few days.
Not sure if it's related but can see loads and loads of DNS failures in the log. I have also seen some odd speedso the router normally shows 80/20 I have seen 42/15 a few times.
Any ideas? I have a WiFi hub running SG4K10002600t
Thanks in advance.
A
bigblockofcheese
I think we have the same issue - and it is highly annoying, isn't it!
OCE_Karl
Hi akeel
I'm not seeing any issues with your line etc, all test are clear.
If you have a Test Socket have you tested directly at this (with a filter) to rule out any internal issues ?
Also, do you have access to another router for testing ?
akeel
Hi Karl. Tried direct and seems the same. I can't find an old router to test with at the moment. Is there anyway one of your guys can log onto my router and see if there is any useful info available from the logs?
Akeel
OCE_Karl
Not seeing anything useful from here.
I've another router on the way so a hardware issue can be ruled out.
akeel
Hi Karl.
Thanks for your help so far. The router arrived yesterday. It seemed ok for the evening. Can see it restarted overnight. Looks like a firmware update has gone on. Has been up for a few hours. So far so good.
Will keep you posted.
Akeel
OCE_Debbie
Hi Akeel
akeel
Hi all,
The new router has been connected for 2.5 days so looks like the issue has been resolved.
Thanks for everyone's help on this matter, much appreciated.
Akeel
OCE_Debbie
Hi Akeel
That's great news, thanks for keeping us updated 🙂
