Router dropping connection constantly
8 REPLIES 8
Hiya, Like the title says for a while now my router has been dropping connection at least 3 times an hour on average.
It did this heavily back in November, stopped for a bit and has started again.
I have ensured all the cables are correctly plugged in, even redid a few. This did not help.
I've tried multiple devices, both wired and wireless so it is not a device issue.
The router is properly ventilated and positioned with a good airflow so I can't imagine it is overheating.
It usually just resets itself but lately the drop out periods have been becoming longer and longer until it wont come back on until I manually go and reset it.
The little green light doesn't just turn red,  it completely turns off.
This is really frustrating.
Thanks in advance for any help.
Hi Gladys. Welcome to the community, your post has been flagged for assistance and you should hear during tomorrow.
Which model router do you have it will be shown on the base.
Have you tried a pin reset?
Hiya, it's
Super Router
HG635
Hardware version G.1.01
Yes I have tried a pin reset, it didn't seem to stop it.
It tends to get worse in the afternoons-night.
Hi Gladyt thanks for that it will help the OCE team tomorrow. They might well offer a replacement, the HG 633 is the newer version of the HG 635 which is not 4eadily available anymore.
Please check your community profile and add your landline phone number if necessary it is used to identify your account and cannot be seen by mere mortals! Please don't post personal details here.
Hi gladyt123
Please can you add your TalkTalk telephone number to your Community Profile, I can then look into this further.
Hi, I used the profile wizard so it should be there
Hi gladyt123
I can't see your TalkTalk landline number in your Community Profile, please can you add this again?
I added it again under personal profile/information and saved changes
Hopefully it is there now?
If not then I'm not sure what I'm doing wrong
Many thanks
I've a new router on the way to see if this helps.
