Router firmware update needed
3 REPLIES 3
I have been having repeated issues with my upload speed (it is only 0.1mbps, whereas download is fine). I have now recieved a new router and this has not resolved the issue. I have checked the firmware and it is SG4K10001400t which I believe is not the most up to date. I have restarted the router and it hasn't updated. Please can you issue a manual firmware update. Let me know which details you need from my router.
Donna Brown
Hi @Donnabrown ,
If you leave your router on 24/7 then it will normally update automatically overnight, however if for some reason it is not updating the staff here can push out an update manually.
Thank you for the response.
I have now updated my profile.
Donna Brown
Hi Donnabrown
Apologies for the delay.
I'm unable to connect to your router, please can you factory reset the router using the pin hole reset for ten seconds, I can then try and connect again.
