Router issues and terrible service
47 REPLIES 47
I've been having issues with my routers for months now. It seems most evenings to drop out for several minutes then reset and come back but can do this several times a night. have paid for a new router and the issue persists. every time I talk to your team they say there is no issue and try and fob me off.
Last night the issue arose and i was on your chat for 2 hours to then be disconnected and told theyll reply tomorrow with the only suggestion they could give being reset my phone?
Today after a further 3 hours on your chat system I was offered an extender for £55. again not solving my issue.
I've had an engineer out and they found no issues with my equipment. Chat have suggested i can pay for an engineer to come out. Why?
I'm so fed up with TalkTalk i want you to end the contract because clearly you have no desire to solve my issue just try and make some more cash.
Aidan
Hi Aidan
I've completed a line test which hasn't detected any faults but I can see re connections on the line.
Which routers have you tested with? (make and model)
Debbie,
I used to have the super router which I believe was made my Huawei and now have the TalkTalk WiFi Hub
Hi Aidan
Is your router currently connected at the test socket?
It is connected to the master socket. Which is the only socket I have.
Hi Aidan
Does this master socket have a test socket?
As far as I'm aware it's doesn't .just the socket for internet and a phone socket
Hi Aidan
Would it be possible to post a photo of your master socket?
Hi Aidan
Thank you. This socket does have a test socket under the faceplate.
Would it be possible to connect the router directly at the test socket?
It's now in the test socket
Hi Aidan
Thank you. Please can you let us know if the connection continues to drop whilst at the test socket?
Can you confirm this is correct. I've had no signal since plugging it in there.Can you confirm this is correct. I've had no signal since plugging it in there.
Hi Aidan
Yes, the micro filter connects to the test socket and then the router connects to the filter.
Are there any lights showing on the router? Do you have a dial tone?
The router is now connected to the internet and the white light is showing on the router. I don't have a landline phone to connect .
Hi Aidan
Please can you let us know if the connection is still dropping in this set up?
It seems to have stayed online all night in the test socket but I'm not sure if it was on all the time .
Hi aidantig,
Thanks for the update. I've re-checked the connection stats and I can still see re-connections on the line. Is the router still connected to the test socket at the moment?
When you tested with the alternative router did you also change the cables and microfilter? As soon as we've confirmed this then we can pass the intermittent connection over to our Network Team for further investigation.
That's a shame. No the cables with the old router were different to the ones I am using on this router . The router is still in the test socket at the moment .
