Router keeps restarting?
9 REPLIES 9
gmwatts
Hi there
Recently my router has started intermittently resetting, roughly every 20 minutes... Which has become incredibly frustrating as it takes about 5-6 minutes to restart and regain the connection.
I've tried swapping the filter and cable but have had no luck. I have also tried accessing the system logs on the router but they aren't showing anything. In the last 5 minutes I've switched on the debug logs option, so maybe that will come up with something.
Obviously, this is hugely frustrating and makes it very difficult to enjoy my Internet connection. Any help would be appreciated, but it seems like an issue with the router..
Thanks in advance
Just trying to fix problems and geek out.
Hi gmwatts
I have updated your router firmware version, please let us know how the connection compares following this.
gmwatts
Hi again, the problem seems to keep happening... Sometimes it's a bit better and lasts an hour or so.. But then it will reset again... And it inevitably happens at the most inconvenient moment, like when I'm watching Amazon Prime or on a WhatsApp call!
However, I can note the update appears to be installed now.
Thank you
Hi gmwatts,
When the router resets, do the lights change?
gmwatts
Hi again, yes, all the lights go off. Then one by one they come back on, with Internet being the last light to come back on. As it does when doing a system reset.
It's starting to get really frustrating now!!
Hi gmwatts,
I'm sorry for the delay. Would you like us to send a replacement router for testing purposes to rule this out?
gmwatts
Hi again
That's OK, I apologise for my own delay in some replies as well.
That would be great if you could send a replacement router to test the connection, yes please.
Thank you for your help
Hi gmwatts
gmwatts
Hi again, it arrived today - very quick, thank you!
I have set it up but am out until this evening, so I'm hoping by the time I get back it will be running at the correct speed and I'll be able to properly test it.
Thanks again - I'll let you know if I have any problems, or if it works out fine.
Test when you can and do report back if there are any issues.
